3 members (2-Ton, 1955 1 Series, Phak1), 126 guests, and 2 robots.
Topics128,091
Posts1,056,449
Members48,443
I'm missing the support rods on my 1957 Chevy suburban. I'm sure they are required so I'm checking to see if maybe someone had the same problem and has a source to find them. If not maybe recommend what size stock to use to Fab a pair.
I'd suggest 3/8" steel round bar- - - - -cut and thread it to whatever length you need. If you don't find a source locally, there's lots of it available on Ebay.
Thanks Jerry.
sub57 - Just in case it may be of any help, below is a snap shot from a 1955.2-59 FAM with details on the supports for your Suburban (3106). Included is an update to show a later part number change (in red). Good luck on your fabricating these rods up! Shouldn't be terribly hard. smile
~ Dan
1951 Chevy 3 window 3100
