Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (JW51, 68ironhead, baldeagle, GMCJammer51, Bill Hanlon), 28 guests, and 1 robot.
Topics128,004
Posts1,055,246
Members48,418
59 Apache 3100
59 Apache 3100
Anyone have a fix for the door handles / window cranks falling off? I thought of drilling into the regulator (splined deal that sticks out of the door) to allow the "set screw) to dig in & some lock tight too. I'd like to hear other thoughts before i move on.
1959 3100, original 235/3 on the tree w/overdrive. Carter YF 2100S carb, 205/75/15 w/front sway bar
Fester - Are your set screws backing out? They originally had a nylon bit that helped keep them locked in place when initially installed. Your drilling a small spot in the regulator for the set screw to positively lock into the shaft, along with a dab of Blue (removable) Loctite should work fine.
If your set screws are on the old and worn out side, you can get some replacements from Jim Carter. smile
~ Dan
1951 Chevy 3 window 3100
Yep, so if you use a new handle with an old door latch or window crank they don`t match well.
The set screw needs to fit in that groove on the shaft. If that happens it cannot come off.
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
59 Apache 3100
59 Apache 3100
Thank you both for your 2 cents & advice. Yes mine keep backing out, but i knew the factory had a trick ( nylon bit, clever) . Its on my short list now.
2 Offline
Original handles used two screws
A set screw inside that was tiny
Then a cosmetic cap screw that locked the internal set screw
With the original double screws the handles stayed on
No one reproduces the double screw sets
You have to go to junk yards and pray to find them
The outer ones are virtually all lost to time
The inner ones are too small to work on their own
-s
Moderated by  ndkid275, Phak1
