Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (baldeagle, LAROKE, 1955 1 Series), 41 guests, and 1 robot.
Topics128,004
Posts1,055,246
Members48,418
#1575409 04/18/2025 9:52 PM
It's kind of crowded where I hold the timing light to time my 261. Does anyone know of a short timing light? Shorter than my 10.5 inch long Sears inductive light?
Thanks!
Innova- - - -mine has a hinge in the middle that allows the timing gun to get into some very tight spots. It's also got a delay flash for checking centrifugal and vacuum advance, and a built in tachometer.
www.ebay.com/itm/405606245923?
I cut 6 inches of the lens end off of a normal timing light and hot wired the battery wires, eliminating the trigger switch all together.
Cost? $0.00.
Insomniac
Insomniac
Use a mirror?
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Moderator, Electrical Bay
I just lay mine on top of the starter (sort of over the side of the solenoid) with the lens up near the access hole for the flywheel. As I recall there's about 10 or 11 inches before you hit the distributor.
~ Jon
Unless you're using a delay flash light to check the operation of the centrifugal or vacuum advance, what's the point of using a strobe light in the first place? Stovebolt engines were designed to use a plain old ice pick type test light to do a perfectly adequate job of setting the spark timing.
Moderated by  MNSmith
