| | | Forums66 Topics128,018 Posts1,055,256 Members48,417 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | It's kind of crowded where I hold the timing light to time my 261. Does anyone know of a short timing light? Shorter than my 10.5 inch long Sears inductive light?
Thanks!
1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Feb 2004 Posts: 29,740 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,740 | Innova- - - -mine has a hinge in the middle that allows the timing gun to get into some very tight spots. It's also got a delay flash for checking centrifugal and vacuum advance, and a built in tachometer. www.ebay.com/itm/405606245923?Jerry
| | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | I cut 6 inches of the lens end off of a normal timing light and hot wired the battery wires, eliminating the trigger switch all together. Cost? $0.00.
| | | | | Joined: Jul 2000 Posts: 2,187 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,187 |
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Mar 2014 Posts: 4,473 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,473 | I just lay mine on top of the starter (sort of over the side of the solenoid) with the lens up near the access hole for the flywheel. As I recall there's about 10 or 11 inches before you hit the distributor.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Feb 2004 Posts: 29,740 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,740 | Unless you're using a delay flash light to check the operation of the centrifugal or vacuum advance, what's the point of using a strobe light in the first place? Stovebolt engines were designed to use a plain old ice pick type test light to do a perfectly adequate job of setting the spark timing. Jerry
