4 members (Bill Hanlon, TooMany2count, 55shaker, Gdads51), 109 guests, and 2 robots.
Topics128,076
Posts1,056,280
Members48,441
I have to believe such a filter exists, but struggling to find it. Is there a common fuel filter that has both inlet and outlet setup for 3/8 inverted flare hardline? Specifically - that would be female inlet/outlet being 5/18-18 IFF…..
Wix has a pretty nice search function by inlet size, but I sure can’t locate an option.
(One of my weird little obsessions is eliminating as much soft line as possible)
1951 3100
7
7 Offline
Search doesn't look good, you can get 3/8 hose barb, 3/8 flare, 6 AN, 3/8" pipe, but I couldn't find 3/8" inverted flare.
Sir Searchalot
Sir Searchalot
Use Wix or Napa 33033. The filter is usually mounted inside the frame, just before the fuel pump. So that needs a hose anyway at filter outlet to pump inlet. The inlet side of filter is just one extra hose. That short hose is attached/clamped at one end to the 33033 inlet and the end other to a hard line flare from tank. The flare acts as a perfect seal for a hose clamp.
You can't have a hard line to the fuel pump inlet. Motor moves independent of frame.
You will be OK with rubber hose. It's made in China. smile
One way, although a tiny bit unwieldy, is to use a pair of these
https://www.tanksinc.com/index.cfm/page/ptype=product/product_id=619/mode=prod/prd619.htm
and a pair of 6an couplers
https://www.summitracing.com/parts/sum-220041
and a modern screen style take apart and cleanable fuel filter, like below, although there are dozens of other versions from other manufactures, all with different micron filters.
https://www.summitracing.com/parts/pfs-10217
Mike
Crusty Old Sarge
Crusty Old Sarge
I'm aware that you are asking for a 3/8" inverted flare style filter. Just food for thought here, I used a Wix 33481 on the my "59 3100 (Ernest). While this filter is a 16x1.5 mm it is fairly common to GM vehicles and readily available. The filter has a flow rate of 1-2GPM at 4.0 Micron filtration. The only obstacle would be having to use metric flare nuts in place of standard 3/8in.
https://www.oreillyauto.com/detail/c/wix/wix-fuel-filter/wix0/33481
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Perfect, Craig. That does seem like the best option of what I’ve seen.
1951 3100
FG481 , or AC Delco GF652 ( 25171792 ) , NAPA SFI 23481, Mid 80's GM 3/8" inverted flare both ends.
Crusty Old Sarge
Crusty Old Sarge
Joe H, this P/N crosses to the same Wix Filter that is listed by RockAuto. The specs call out a 16x1.5 thread.
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
Would it take a bubble flare to make that metric fitting work?
1951 3100
Crusty Old Sarge
Crusty Old Sarge
No, nothing special just a standard double flare will work.
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
The m16-1.5 flare nuts look weird compared to Sae. Threads stop further from the end.
1951 3100
Crusty Old Sarge
Crusty Old Sarge
They will seat just fine. grin
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
1951 3100
I see that now, you can still use the FG481 with a couple of adaptors, Weatherhead #1446 or these https://www.fastenal.com/product/details/0443572
I used a spectre 2369 filter which has 1/8 npt female threads.
Then purchased fittings with 1/8 npt male and the 3/8 IVF female ends.
