3 members (Gray_Ghost, Scott, 1 invisible),
81
0
Mod | | | Forums66 Topics128,050 Posts1,055,761 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2014 Posts: 3,681 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,681 | I have to believe such a filter exists, but struggling to find it. Is there a common fuel filter that has both inlet and outlet setup for 3/8 inverted flare hardline? Specifically - that would be female inlet/outlet being 5/18-18 IFF…..
Wix has a pretty nice search function by inlet size, but I sure can’t locate an option.
(One of my weird little obsessions is eliminating as much soft line as possible)
1951 3100
| | | | | Joined: Feb 2016 Posts: 1,985 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,985 | Search doesn't look good, you can get 3/8 hose barb, 3/8 flare, 6 AN, 3/8" pipe, but I couldn't find 3/8" inverted flare.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Use Wix or Napa 33033. The filter is usually mounted inside the frame, just before the fuel pump. So that needs a hose anyway at filter outlet to pump inlet. The inlet side of filter is just one extra hose. That short hose is attached/clamped at one end to the 33033 inlet and the end other to a hard line flare from tank. The flare acts as a perfect seal for a hose clamp. You can't have a hard line to the fuel pump inlet. Motor moves independent of frame. You will be OK with rubber hose. It's made in China.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2007 Posts: 3,383 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,383 | I'm aware that you are asking for a 3/8" inverted flare style filter. Just food for thought here, I used a Wix 33481 on the my "59 3100 (Ernest). While this filter is a 16x1.5 mm it is fairly common to GM vehicles and readily available. The filter has a flow rate of 1-2GPM at 4.0 Micron filtration. The only obstacle would be having to use metric flare nuts in place of standard 3/8in. https://www.oreillyauto.com/detail/c/wix/wix-fuel-filter/wix0/33481
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Jan 2014 Posts: 3,681 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,681 | Perfect, Craig. That does seem like the best option of what I’ve seen.
1951 3100
| | | | | Joined: Feb 2000 Posts: 5,202 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,202 | FG481 , or AC Delco GF652 ( 25171792 ) , NAPA SFI 23481, Mid 80's GM 3/8" inverted flare both ends. | | | | | Joined: Mar 2007 Posts: 3,383 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,383 | Joe H, this P/N crosses to the same Wix Filter that is listed by RockAuto. The specs call out a 16x1.5 thread.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Jan 2014 Posts: 3,681 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,681 | Would it take a bubble flare to make that metric fitting work?
1951 3100
| | | | | Joined: Mar 2007 Posts: 3,383 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,383 | No, nothing special just a standard double flare will work.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Jan 2014 Posts: 3,681 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,681 | The m16-1.5 flare nuts look weird compared to Sae. Threads stop further from the end.
1951 3100
| | | | | Joined: Mar 2007 Posts: 3,383 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,383 | They will seat just fine.
1951 3100
| | | | | Joined: Aug 2023 Posts: 18 'Bolter | | 'Bolter Joined: Aug 2023 Posts: 18 | I used a spectre 2369 filter which has 1/8 npt female threads. Then purchased fittings with 1/8 npt male and the 3/8 IVF female ends. | | |
