0 members (), 118 guests, and 1 robot.
Topics128,113
Posts1,056,619
Members48,450
#1573158 03/22/2025 11:16 AM
Hi there,
I am about to replace the brake lines throughout the truck and seeking advice whether to go copper/nickel or zinc (coated mild steel I think)? tubing.
I have heard with copper/nickel if later on I decide to undo the nut there is a good chance it binds and I risk twisting off about an inch of tubing.
After any advice, suggestions is it worth going copper/nickel or stick with steel.
Any benefits of one against the other?
Thank you.
Dawso #1573159 03/22/2025 12:06 PM
I don’t know why the tube nut would be any more prone to binding on NiCopp than it would on any other line. If you’re worried about it, maybe just a dab of antiseize between the line and nut.
The flexibility and corrosion resistance of the NiCopp would outweigh that concern (if it is a concern)…in my opinion.
1951 3100
Dawso #1573162 03/22/2025 1:58 PM
7
7 Offline
I re-plumbed mine with copper/nickel, no problems with backing the nut off.
Dawso #1573165 03/22/2025 2:36 PM
Dawso, Your topic best fits in the Driveline forum, so it's been moved there for further conversation and help.
Just a note from my own fairly recent experience with fabricating replacement brake lines, I found the NiCopp to be much easier to flare and bend than the zinc coated steel line. No issues with backing the nut off in my use. wink
~ Dan
1951 Chevy 3 window 3100
Dawso #1573177 03/22/2025 5:44 PM
U
U Offline
I bought a complete preformed set for my '46 truck and I went with the steel lines, then sprayed them with clearcoat paint. I guess I only saw steel or stainless when I was shopping.
~ John in Utah
Here We Go
Follow in his DITY Bay
Dawso #1573182 03/22/2025 8:03 PM
Another advantage of copper/nickel tubing is that the material is more malleable than steel (and a lot more than stainless steel) making the flaring process easier. You are less likely to crack the flare and the steel nut will deform the flare easier making it less likely to leak. I have used this material for two complete truck restorations and half the tubing on another and there has never been leaks or failed flares.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
