4 members (Hanks custodian, Otto Skorzeny, Gray_Ghost, 1 invisible), 73 guests, and 2 robots.
Topics128,060
Posts1,055,833
#1572175 03/10/2025 4:24 AM
I am getting ready to drill my 261 for this front mount. I am using the mount from the 235 I took out.Looking at and reading the posts here, I don’t think my bolts were correct. All were carriage bolts (all 3/8”) , the center 2 were
2 3/4” long with short stiff springs. Were springs ever used? What are the size and lengths of the carriage bolts that should be used?
AD Addict & Tinkerer
[BY MODERATOR]: Rick46ia, I moved your post out of an existing thread so you’ll get responses to your specific issue. It’s always better to start a new thread rather than piggybacking on to an existing thread. Readers may confuse your issue with the original posters issue.
Phil
Project Journals
Stovebolt Gallery Forum
Rick, From looking in a 1942-47 Shop Manual and 1929-46 Master Parts book, there are no springs used in the engine mount for your '46. Nor where there springs used in the later AD series engine mounts. This recent thread from John In Utah discusses the conversion of the later 1960-62 235/261 engine front mount plate. I believe it address the hardware needs too.
This Front Engine Mount Legacy Tech Tip has some great info to help answer your questions too. Got enough, or more questions???
~ Dan
1951 Chevy 3 window 3100
Thanks, I will check out the other posts.
I have obtained a complete NOS cast aluminum front engine mount..... the cast part replaces the rubber........ and it came in an original beaten GM cardboard box......
Any idea why they would negate the rubber vibration dampener?? or what it fits?? To me it is a conversion piece no intention of using it......
Bob C.
CMP Heaven
The Hammond Barn
