9 members (DaveV, 55shaker, TUTS 59, Phak1, Rusty Rod, RLB, WICruiser, Gdads51, 1 invisible),
85
Mod | | | Forums66 Topics128,056 Posts1,055,789 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2024 Posts: 99 'Bolter | | 'Bolter Joined: Oct 2024 Posts: 99 | I am getting ready to drill my 261 for this front mount. I am using the mount from the 235 I took out.Looking at and reading the posts here, I don’t think my bolts were correct. All were carriage bolts (all 3/8”) , the center 2 were 2 3/4” long with short stiff springs. Were springs ever used? What are the size and lengths of the carriage bolts that should be used?
| | | | | Joined: Feb 2019 Posts: 4,476 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,476 | [BY MODERATOR]: Rick46ia, I moved your post out of an existing thread so you’ll get responses to your specific issue. It’s always better to start a new thread rather than piggybacking on to an existing thread. Readers may confuse your issue with the original posters issue.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Sep 2009 Posts: 5,825 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,825 | Rick, From looking in a 1942-47 Shop Manual and 1929-46 Master Parts book, there are no springs used in the engine mount for your '46. Nor where there springs used in the later AD series engine mounts. This recent thread from John In Utah discusses the conversion of the later 1960-62 235/261 engine front mount plate. I believe it address the hardware needs too. This Front Engine Mount Legacy Tech Tip has some great info to help answer your questions too. Got enough, or more questions???
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Oct 2024 Posts: 99 'Bolter | | 'Bolter Joined: Oct 2024 Posts: 99 | Thanks, I will check out the other posts. | | | | | Joined: Aug 2000 Posts: 248 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 248 | I have obtained a complete NOS cast aluminum front engine mount..... the cast part replaces the rubber........ and it came in an original beaten GM cardboard box......
Any idea why they would negate the rubber vibration dampener?? or what it fits?? To me it is a conversion piece no intention of using it......
Bob C. CMP Heaven The Hammond Barn
