0 members (),
134
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2016 Posts: 177 'Bolter | | 'Bolter Joined: Dec 2016 Posts: 177 | I'm upgrading my master cylinder on my '55.1 Chevy p/u 3100 from original m/c to the dual m/c. I've acquired a drum/drum m/c to install, but I'm having a hard time determining if proportions and/or residual valves are needed or should be used. Placement of my new m/c will be the same place using the bracket I got from Precision On Line (POL). Please advise.
S2 Stewart2 1955.1 3100 Both Owner and P/U have lots of miles, lots of history and need LOTS of TLC Jack of several trades and experiences; Master of none
| | | | | Joined: Apr 2005 Posts: 2,101 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,101 | Proportioning valves are normally not required on drum/drum applications. Most master cylinders for drum/drum applications should have an internal residual valve. Check with your supplier. However, they may not know as many just push parts out and don't know the technical aspects of their products. Fred
| | | | | Joined: Dec 2016 Posts: 177 'Bolter | | 'Bolter Joined: Dec 2016 Posts: 177 | Thank you, Fred! My new master cylinder is a CPP (Classic Performance Product) and, according to their response on the web, they do have an internal residual valve. I just didn't think about it having an internal one. So, thanks again!
