2 members (Hotrod Lincoln, Shade Baby), 66 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,458
I'm upgrading my master cylinder on my '55.1 Chevy p/u 3100 from original m/c to the dual m/c. I've acquired a drum/drum m/c to install, but I'm having a hard time determining if proportions and/or residual valves are needed or should be used. Placement of my new m/c will be the same place using the bracket I got from Precision On Line (POL). Please advise.
S2
Stewart2
1955.1 3100
Both Owner and P/U have lots of miles, lots of history and need LOTS of TLC
Jack of several trades and experiences; Master of none
Proportioning valves are normally not required on drum/drum applications. Most master cylinders for drum/drum
applications should have an internal residual valve. Check with your supplier. However, they may not know as many
just push parts out and don't know the technical aspects of their products.
Fred
Thank you, Fred! My new master cylinder is a CPP (Classic Performance Product) and, according to their response on the web, they do have an internal residual valve. I just didn't think about it having an internal one. So, thanks again!
S2
Stewart2
1955.1 3100
