2 members (Joe H, moparguy), 118 guests, and 2 robots.
Topics128,093
Posts1,056,480
Members48,444
Have a ‘47 Chev. 3100 with a steering wheel horn button I can’t figure out.
I’m assembling it wrong or something’s warn or it’s an operator malfunction!
Not sure of assembly order. Can’t find a diagram to help. Steering wheel- spring- contact plate- nut- horn button?
I know it’s wired live and when you press the horn button the circuit is completed and horn blows.
Problem is when I put the contact plate around the steering shaft a contact is made, blowing the horn.
What am I missing????
If I recall, the stackup is:
spring
wheel
plate
nut
horn button
1950 Chevrolet 3100 (Ol' Roy)
There is a diagram somewhere on this forum.
Thanks for the tip, that helps. I’ll look for the needle in the haystack. Picture is always helpful.
I tried to find it but couldn't. I am pretty certain , though that the spring goes on first and then the steering wheel.
Jim, I think some helpful instructions and pictures can be found in the Kip Bonds Repairing Your Horn Legacy Tech Tip. Even though this was on his '41, I think the sequence and parts are the same for your '47.
An excerpt of the sequence of reassembly is in the screen shot below. smile
~ Dan
1951 Chevy 3 window 3100
Is the '47 assembly any different than a '50? Are you assembling this with the battery connected? If so, I would disconnect the battery to make it easier. Also if similar to a '50 what I see above missing is the contact pin. Thus:
Spring
wheel
contact pin
plate
nut
horn button
Craig
Thanks for all the tips guys.
My truck is a ‘47 AD. I think it was an early “hybrid.” Parts scavenged from many vehicles over the years! The innards of my wheel aren’t the same as rage Bins photos. Inhave a flat plate and no prongs on the conical insert. I’m thinking perhaps this was left over parts from the Art Deco model ‘46.
I did find an article and picture that resembled what I have. Went to Ace and got a temporary spring and played with the parts until I goy it to work. Seems I found the horn button seems to “rock” due to the spring leading to the horn working. I have ordered a spring but from a ‘46/model for a better fit.
Bottom line is....it works! Even though I may have jerry-rigged I! Just have to tweak it I guess.
Thanks for all your help!!!!!
Toot! Toot! - Glad to hear its working.
Craig
