4 members (klhansen, fonz8261, TUTS 59, carbking), 104 guests, and 2 robots.
Topics128,070
Posts1,055,892
Members48,428
Okay experts. I've removed one side of my exhuast system
This is so a bung can be welded in. I plan on replacing the whole system all new pipes mufflers and tips
The header collector measures 2.5 inches. The pipe is 2 inches. Searching most mufflers are 2.5 inches inlet/outlet. I was planning on using the original from collector to just past the 90 degree bend (preserve the bung). This is on a 52 with a 383 stroker. I'm not opposed to replacing the entire system. Just watching my $. Thanks in advance
Mufflers comes in any diameter you can want.
What is your actual question? You say you plan on replacing everthing in your first paragraph, but then say you plan to use the original from the collector.
When you say "the original", what pieces are you wanting to keep and what are you wanting to replace?
Pictures would help.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
If its for performance check out Engine Masters on Prime if you have it - they ran dyno tests on a variety of exhaust tube diameters as well as common mufflers, headers vs manifolds etc
1949 Chevrolet 3/4 Ton - Still Solid. Regular Driver
OT Vehicles:
1925 Hudson Brougham Super Six
1950 Chevrolet Styline (Parts)
1952 Canuck Pontiac Sedan Delivery (Well Underway)
1973 F250 4x4 Highboy
1977 F250 4x4 Lowboy
Okay I was vague, if the 2in dia pipe is okay then I'll keep the header collector and the portion where it curves to parallel to the floor boards. Most of the mufflers I've researched are 2.5 in in dia. I will be definitely replacing mufflers. I can always use a reducer 2in to 2.5.
I was wondering if 2in is too small for a 383
Yes I've seen engine masters. Good show
I'm embarrassed to post this pic, extremely ugly
Oh not at all. "Fixed is Fixed" in any event, as they say.
If anyone is looking around under my vehicle at my exhaust welds, I'm sure they're life is going in a direction they hadn't predicted.
If it's a stock 216/235 I doubt you'll notice much difference between 2" & 2-1/4" or larger
I can say in my own perception, with a V8 2.5" duals sounds better than 2-1/4" duals but... that's pretty subjective. On the street I very much doubt there's "seat of the pants" kind of performance difference or mileage but...
OT Vehicles:
My temporary exhaust is much uglier, 4.3 vortec Y-pipe to a cherry bomb to a flex pipe and then a short down pipe. Should be good enough to get it to the muffler shop to dress it up smile
1936 GMC T-14 restro-mod
Are you doing true duals or are you putting in a y-pipe to a single out the back?
What is your use case? Is this a street machine? Stoplight racer? Drag rig?
The crux of the question is how high you plan to rev it under normal conditions.
For a 383 stroker engine, a typical exhaust pipe diameter would be 2.5 inches; however, depending on the specific application and desired power level, you might consider a slightly larger 2.75 inch pipe for optimal performance. google it
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
I used 2 1/2" front to back on my 383 installation (actually the exhaust shop did the work). Not intending to use the performance capability of the 383 but it's what I built to go into the truck.
1949/50 3600 Project
Follow in Project Journals
7
7 Offline
With a true dual system, 2.25 - 2.5 inch would be fine as long as you don't choke down at the mufflers. On my 2 ton with the 283, I used 2 in. pipe with 2.25 in. mufflers, the manifolds aren't 2.5 in. so it's not restricting at that point.
