Winter is Coming
A good Tech Tip WINTERIZING YOUR TRUCK including a link back to the Forums for additional tips.
From what I understand, replacing the wood in a panel truck is no small task. The outer most boards go under the body and all the boards are held down in the rear by special flat topped bolts so they sit flush. I think they are called elevator bolts. No doubt yours are rusted solid and you will break one or two getting them out. The entire project is possible but a ton of work. Sand and stain or do what most do, lay carpet or fabric down to make it look clean. Show us a pic of what you are working with.
1947.2 GMC 1/2T SWB panel 1947.2 GMC 1/2T long bed 1948 GMC 1/2T short bed
Anyone know if the wood/stainless kits for pickup beds are the same for a panel?
The web site for Jim Carter Truck parts in Independence, MO has a technical section that I believe give the dimensions of the wood in the floors of panel trucks. Same for Suburbans?
~ Dan 1951 Chevy 3 window 3100 Follow this story in the DITY Gallery "My Grandpa Carl's Truck and How it Became Mine" 1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
