1 members (klhansen), 147 guests, and 0 robots.
Topics128,162
Posts1,056,939
Members48,458
Anyone know if the wood/stainless kits for pickup beds are the same for a panel?
'48 Panel
Not for TF panels. I was able to use stainless from a fleetside kit w/ enough strips to make
them work. Measure what you have and see.
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
Thank you?
'48 Panel
Professional procrastinator
From what I understand, replacing the wood in a panel truck is no small task. The outer most boards go under the body and all the boards are held down in the rear by special flat topped bolts so they sit flush. I think they are called elevator bolts. No doubt yours are rusted solid and you will break one or two getting them out. The entire project is possible but a ton of work. Sand and stain or do what most do, lay carpet or fabric down to make it look clean. Show us a pic of what you are working with.
1947.2 GMC 1/2T SWB panel
1947.2 GMC 1/2T long bed
1948 GMC 1/2T short bed
The web site for Jim Carter Truck parts in Independence, MO has a technical section that I believe give the dimensions of the wood in the floors of panel trucks. Same for Suburbans?
Life is good on Windy Ridge!
I've launched the project. All the bracing underneath is rotten, including the wood.
'48 Panel
paint on the interior
'48 Panel
closer
'48 Panel
Looking really great! thumbs_up
~ Dan
1951 Chevy 3 window 3100
Very nice indeed dance
Wow !
A difficult job requirig meticulous work. Kudos to you for a beautiful result.
Regards, Mark
1958 GMC Suburban Carryall
Never accept a drink from a urologist!
