1 members (carbking), 144 guests, and 4 robots.
Topics128,186
Posts1,057,211
Members48,465
#157042 12/07/2003 11:02 PM
Junior Member
Junior Member
I just finished a 24x36 shop and now I need a heater for it. I would like a wall hung and would like an electric no hassle heater. I have seen a few on the internet, but it's hard to tell if they are any good or not.
Can anybody recommend a heater, or can give me any tips on what to look for?
Mike: You didn't want to go with gas? My shop is all most same size hair smaller 4 yrs old went with a Red DAWG ceiling mounted does great job especially with ceiling fan added to center of ceiling. Check with a few electrical contractors see what the advise. popcorn The Truth is Out There (At least ya got a shop!!)
In my fish hatchery I also used gas. Much cheaper around here. I like what they call a zero clearance heater. You mount it on an outside wall and don't need a flue all the way to the roof. It just has a little round hood on the outside of the wall. Cheap and easy to install. You can safely put things right next to the heater.
54 3100 with 235
62 flatbed dump C60 with 261
Gas here also. I use a Hi-intensity infrared Dayton hanging heater. I think it is rated at 49k BTUs, the natural gas model puts out 60k. I wanted electric but none come close to the Dayton. I use a 250 gal propane tank, fill once a year @$120-140. No pilot, electronic ignition. Heats my 30x30x10 like you can't believe. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
i use a daton 75,000 btu smile . (gas)
just a plan jane ceiling mounted heater, heats up a 20 X 30 shop quick grin .
i got it used (two years old) at an auction for $100.
overkill. . . i think not :p
Briank
Sometimes, David beats Goliath. Nobody talks, however, about how many little guys Goliath already beat into the ground. . .
Waste oil heater. It turns a liability into an asset. Gas prices are kind of high right now and waste oil is free. Two years ago, my inlaws were spending $300 a month to heat their house to 65 degrees with natural gas, and $0 a month to keep their shop at 80 degrees. However, you do need a steady supply of used oil during the winter.
Phil
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
propane gas for me. i have a 24x30. i mounted it to the rafter"cord" and it does a beautiful job. its electonic and really does the trick. the best part is i ran a line from the big house tank and i can lie about how much it cost to heat the house and for the wife to keep the doors closed on the house to help pay for mine!!!
Moderated by  MNSmith
