2 members (Deegs53, Bucker),
144
Mod | | | Forums66 Topics128,183 Posts1,057,194 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2003 Posts: 13 Junior Member | | Junior Member Joined: Oct 2003 Posts: 13 | I just finished a 24x36 shop and now I need a heater for it. I would like a wall hung and would like an electric no hassle heater. I have seen a few on the internet, but it's hard to tell if they are any good or not.
Can anybody recommend a heater, or can give me any tips on what to look for? | | | | | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Mike: You didn't want to go with gas? My shop is all most same size hair smaller 4 yrs old went with a Red DAWG ceiling mounted does great job especially with ceiling fan added to center of ceiling. Check with a few electrical contractors see what the advise. popcorn The Truth is Out There (At least ya got a shop!!) | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | In my fish hatchery I also used gas. Much cheaper around here. I like what they call a zero clearance heater. You mount it on an outside wall and don't need a flue all the way to the roof. It just has a little round hood on the outside of the wall. Cheap and easy to install. You can safely put things right next to the heater.
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Gas here also. I use a Hi-intensity infrared Dayton hanging heater. I think it is rated at 49k BTUs, the natural gas model puts out 60k. I wanted electric but none come close to the Dayton. I use a 250 gal propane tank, fill once a year @$120-140. No pilot, electronic ignition. Heats my 30x30x10 like you can't believe. Brian | | | | | Joined: Feb 2003 Posts: 66 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 66 | i use a daton 75,000 btu  . (gas) just a plan jane ceiling mounted heater, heats up a 20 X 30 shop quick  . i got it used (two years old) at an auction for $100. overkill. . . i think not :p Briank
Sometimes, David beats Goliath. Nobody talks, however, about how many little guys Goliath already beat into the ground. . .
| | | | | Joined: May 2003 Posts: 328 Shop Shark | | Shop Shark Joined: May 2003 Posts: 328 | Waste oil heater. It turns a liability into an asset. Gas prices are kind of high right now and waste oil is free. Two years ago, my inlaws were spending $300 a month to heat their house to 65 degrees with natural gas, and $0 a month to keep their shop at 80 degrees. However, you do need a steady supply of used oil during the winter.
Phil
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | propane gas for me. i have a 24x30. i mounted it to the rafter"cord" and it does a beautiful job. its electonic and really does the trick. the best part is i ran a line from the big house tank and i can lie about how much it cost to heat the house and for the wife to keep the doors closed on the house to help pay for mine!!! | | |
