2 members (J Lucas, pauld),
123
Mod | | | Forums66 Topics128,183 Posts1,057,263 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2022 Posts: 9 'Bolter | | 'Bolter Joined: Apr 2022 Posts: 9 | Just acquired a 1 Ton Dually dump that is pretty much stock and I am looking for a recommendation for a good, comprehensive, engine manual that could be purchased. Husband is a long time tinkerer with most gas engines but, is new to the diesel engines. This engine only has 53K original miles and was used exclusively in a large private park. Will post some photos when we have the truck at our location. Thank you in advance for your input, Virginia | | | | | Joined: May 2015 Posts: 11,172 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,172 | Haynes has a Diesel Engine manual that covers the 6.2L among others. Not necessarily recommending Haynes, but that's a start.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Sep 2011 Posts: 1,461 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,461 | You're giving me flashbacks! Change fuel filters religiously, Stanadyne (Roosa master) pumps will suffer from lack of lubrication before you notice lack of power. Never use starting fluid on these beasts, I've seen them bend rods, ingesting snow or water was another issue that would bend rods, etc.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Feb 2002 Posts: 2,896 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,896 | | | |
