8 members (Hotrod Lincoln, sudsyz, Chip O, Gdads51, 1955 1 Series, stlcardinalsguy, tclederman, 1 invisible),
67
0
Mod | | | Forums66 Topics128,210 Posts1,057,456 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2022 Posts: 116 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 116 | Well thought I was Nolan Ryan and threw my dog his favorite rubber toy and it hit the BBQ glanced off that and hit my Cameo bed broadside just fwd. of the tire and now I have a dent in it. What would be the best way to pop it out. It was totally my fault. Thanks there Bolters. .
Last edited by Gdads51; 02/08/2025 2:26 PM. Reason: add detail to title about truck
| | | | | Joined: May 2015 Posts: 11,188 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,188 | If you can get behind it, use a slapper on front and back. You may be able to get it out without messing up the paint. It's worth a try, anyway.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2022 Posts: 116 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 116 | A slapper meaning your hand, I didn't think fiberglass would dent? | | | | | Joined: Sep 2009 Posts: 6,049 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,049 | I've never seen fiberglass dent. Those Cameo bed side panels are hard to find and like any other fiberglass can be tough to repair. If it has a depression where they toy hit, it may mean there is structural failure of the fiberglass. It's been decades since I did any fiberglass work, so not sure how to suggest further inspection/evaluation to see what the damage is, other than to remove the panel entirely. Lots of work involved and makes me cringe, just thinking about it.  I think Kevin missed that you are talking about a "Cameo" truck with the fiberglass bed side panels. I tweaked your thread title to add that detail.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Sep 2010 Posts: 2,337 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,337 | Maybe just let it sit in the sun to see if it finds its way back to shape .Another thought would be to clean the underside really good and maybe put a layer of cloth on the back and if it can be supported so it is straight until it dries to keep it in place . | | | | | Joined: Feb 2016 Posts: 1,996 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,996 | It is difficult for me to imagine a rubber dog toy hitting the side of the truck with enough force to push the fiberglass out of shape. Did it chip the paint/gelcoat, are there fiberglass strands showing as in a crack or deep gouge? It just so happens that I am in the process of some fiberglass repair on our older jet ski, it's very similar to working any body panel, lot of labor and meticulous shaping, sanding, etc. I've done small glass repairs in the past, dually truck fenders, Corvette front air dam, etc., no rocket science involved.
| | | | | Joined: May 2015 Posts: 11,188 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,188 | I think Kevin missed that you are talking about a "Cameo" truck with the fiberglass bed side panels. Yep.  If it did crack the underlying fiberglass mat, what I'd do is scuff the back of the panel, apply some resin and embed a piece of fiberglass cloth to reinforce it. Then you're going to have to sand, fill and repaint the outside. Not a fun job, it'll be messy. If the panel is removable, do that so you can lay it flat so you don't have resin dripping on you. I crunched a fiberglass cab step on my '99 Ford, and managed to repair it. Had to farm out the painting and re-application of the bedliner tread material, so it wasn't cheap.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2004 Posts: 29,888 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,888 | Can you reach the damaged area from behind the bed side? If so, deflate a beach ball, stuff the flattened ball behind the damaged area, and GENTLY inflate it to support the panel while you grind, lay up a cloth patch, and soak it with resin from the outside. Once it's well-cured, sand, shape, use a thin layer of filler if necessary, and prime and paint. Not an easy, or an inexpensive repair! Jerry
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | A LITTLE heat may help you work with it. | | | | | Joined: May 2015 Posts: 11,188 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,188 | Unfortunately heat won't help. Fiberglass is a thermosetting plastic. It doesn't soften with application of heat.
