| | | Forums66 Topics128,136 Posts1,056,426 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2024 Posts: 28 'Bolter | | 'Bolter Joined: Jun 2024 Posts: 28 | I am looking to move the tank to the rear and put the filer in the tail light on my 61. I don’t find a tank the says it fits the 61 K 10. I do find some 15 gal universals tanks that size wise would fit between the rails. Is there some issue with fitting a side fill tank in the 61 4x4? Is there another option that bigger than 15 gal. Thanks
GSS
| | | | | Joined: Nov 2004 Posts: 2,413 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,413 | I agree with Mike. Check out Tanks Inc in Iowa. They may have something or could build you what you need. I know others on this site have utilized OEM tanks from other vehicles. Hopefully, one of them will chime in and help solve your dilemma.
If all else fails, you may just have to grab a tape measure and hit the scrap yards.
I agree, 15 gallons doesn’t seem big enough for a full size truck.
Good luck.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Jun 2024 Posts: 28 'Bolter | | 'Bolter Joined: Jun 2024 Posts: 28 | Thanks! That could be an issue, There is 2.25 inches. I am fairly sure I could shim the cross supports to get a little more. The truck is lifted so I would have to drop the gate every time I filled it with a bed fill, and I don’t like the idea of dragging a hose over the paint.
GSS
| | | | | Joined: Sep 2011 Posts: 1,456 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,456 | I agree, 15 gallons doesn’t seem big enough for a full size truck.
Good luck.
John Standard tank is 16 1/2 gallon, RPO tank 20 1/2 gallon. I found a nice RPO tank in a salvage yard C60 several years ago, helps with range anxiety! Didn't matter much when these rigs were new, gas station in every small town.
Last edited by Gdads51; 02/08/2025 11:10 PM. Reason: fix quote to display correctly
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Jan 2022 Posts: 2,468 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,468 | 15 gallons may not sound big enough, but if this truck doesn't get driven a lot a smaller tank would reduce the amount of "go bad" that happens when today's gas sits in the tank for months.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: Jun 2024 Posts: 28 'Bolter | | 'Bolter Joined: Jun 2024 Posts: 28 | I planning on it being a driver. I got a drive-chain engine transmission from a 2004 1500. Still got to get a right side dump transfer case. I think that set up will put me at 15-16 mpg.
GSS
| | | | | Joined: Sep 2009 Posts: 5,918 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,918 | Gary - Here is one of several older threads related to moving the fuel tank as you described. But it (and the other thread referred to inside this one) might have more connection with your stated later engine as it includes a provision for an in-tank fuel pump. Also, if you want to go with a larger capacity tank, this 18 gallon tank might work if you have the space to fit it in.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Feb 2023 Posts: 381 'Bolter | | 'Bolter Joined: Feb 2023 Posts: 381 | I used a 21 gal side fill kit from one of the vendors, don’t recall which one, in my 66 c10 short stepside. I know several vendors sell it as I viewed a how to U-turned video from Brothers. Details are in my Project thread. FWIW, tank is said to be a Blazer unit. Thinking about it, I believe it came from CJ Pony. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Thanks! There is 2.25 inches. The tank I linked above has a 1-1/4" filler neck and 1-1/4" fuel hose has a 1-3/4" diameter, so you should be able to use that tank. I believe it's also setup for using a in-tank fuel pump which you might need with your newer engine setup. Mike B  | | | | | Joined: Jun 2024 Posts: 28 'Bolter | | 'Bolter Joined: Jun 2024 Posts: 28 |
GSS
