| | | Forums66 Topics128,162 Posts1,056,942 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#15689 05/24/2004 3:38 PM | Joined: Nov 2003 Posts: 113 Member | | Member Joined: Nov 2003 Posts: 113 | Help!!
I apparently have a 1954 ish aftermarket oil filter assembly and cannot find a filter. The "pot" (as I call it) that the filter cannister goes into is 4" tall, 4" wide, and the center shaft is 1/2 " to 5/8". I tried local supply houses and they have ordered some in that they thought would fit, but no luck. Even Mr. Goodwrench was stymied! If anyone has an idea what model number and make oil filter I need, please let me know!!!
Thanks!!
Bruce (I love My Truck) Miller
1954 5 Window 3100 Chevy Pickup - Driver 1929 **** Model A Pickup - Restoration
#15690 05/24/2004 3:57 PM | | Anonymous Unregistered | | Anonymous Unregistered | | | |
#15691 05/24/2004 5:51 PM | Joined: Nov 2003 Posts: 117 Member | | Member Joined: Nov 2003 Posts: 117 | One of these should fit: Purolator P-51 or L20051 Fram C-30, C3, or C3P Carquest 85021 NAPA 1006 (Fram canister) NAPA 1100 (AC canisters)
Fram canisters have a crimped bottom AC canisters have smooth bottom.
Winona 1949 3100 5 Window Deluxe Cab
#15692 05/31/2004 1:28 AM | Joined: Nov 2003 Posts: 113 Member | | Member Joined: Nov 2003 Posts: 113 | Just for closure, I called WIK and gave them the dimensions for the oil filter container attached to the manifold. I was right, it isn't anywhere the size of the original. I soke with someone the other day at Fram that said they used either an AC Declco (then just AC) filter case and cannister or a Fram case and cannister. Each one was a little different in size. I believe that mine is the Fram assembly.
For the record, WIK thins it will yake a 51107 filter cannister, so I've ordered one from NAPA. If it fits I'll order a dozen more.
Thanks for the help!!
#15693 05/31/2004 1:59 AM | Joined: Jul 2003 Posts: 252 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 252 | Small world, just two hours ago I took the old Fram canister I got with a core motor from a '55 apart to start cleaning it up to install on the '61. It IS a Fram cannister with remnants of orange paint and the crimped bottom. The filter element inside of it(probably for the last 35 years)has clearly marked "AC P-115" then below that "MS 35346" and below that "Heavy Duty Junior Oil Filter" (heavy duty junior, seems like an oxymoron). Perhaps you could cross reference the AC P-115. BTW, it is 5" high, and about 4.25" in diameter. HTH | | |
