8 members (John Dlugos, dt235sd, rfs56trk, BCBill, Otto Skorzeny, Dusty53, Buckeye998, Chip O), 192 guests, and 1 robot.
Topics128,101
Posts1,056,172
Members48,436
#1568922 01/26/2025 8:28 PM
I need a temperature sending unit in order to use my original gauges (1946 Chevy 1/2 ton). We've not found them sold separately, and we don't know if there's a work-around. (Dolphin/modern Gauges isn't an option. I'm keeping everything original, minus swapping to 12V.)
Any advice, or obscure vintage parts stores we've not found? How have you rigged yours to work? TIA
1946 Chevy
Getting started on Bruno
You can't buy happiness but you can buy a truck ... and that's pretty much the same thing.
The "sending unit" isn't a separate item- - - -it's incorporated into the gauge with a capillary tube that can't be replaced separately. There's a liquid in the sending bulb that evaporates and moves the temp needle with vapor pressure- - - -no electricity involved. It might be possible to get the gauge rebuilt to original specifications by a professional restorer.
Professional procrastinator
I think I have an NOS gauge that will fill your needs. I will look for it and get you some pics by tomorrow.
1947.2 GMC 1/2T SWB panel
1947.2 GMC 1/2T long bed
1948 GMC 1/2T short bed
That would be so awesome! Thank you so much for checking!! I'm getting so close to finally getting on the road.
1946 Chevy
Here are a couple pics I took. I put it under the hot water at the kitchen sink and it responded immediately. Send me a PM if you are interested. I may have a used one if that will more closely match your existing gauges. I also have all the other gauges in NOS condition as well, just in case you want to go all brand new.
I'll definitely take it, please. PM me your info. Thank you so much!!
I installed my wiring harness about a month ago, and I went through my odometer and cleaned it and such. This is what I have to work with.
1946 Chevy
PM sent
Moderated by  ndkid275, Phak1
