2 members (pdlightning, Tronman), 104 guests, and 3 robots.
Topics128,094
Posts1,056,064
Members48,433
#1566459 12/25/2024 3:04 PM
Been very busy last couple of years. Dad and Mom both failing health. Unfortunately both have passed. I just recently (12/19/2024) retired. I hope to put more miles on the 64. Have been chasing/concerned with a knocking sound from the driveline, i now believe it to be the torque converter. (turbo 350). Not hard or expensive to change. Not planning it to be everyday driver, but sure hope to put more miles on it.
blu1964 #1566470 12/25/2024 7:58 PM
RLB Offline
Sorry to hear about your parents. Looking forward to hearing more about the 64, maybe even post a photo or two. RB
1966 C-10 Short Stepside
HiPo
Step-by-step ~ and on-going resto build
in the Project Journals
blu1964 #1566623 12/28/2024 12:07 AM
I will work on the photos, not much of a computer guy. SWB, 2wd, currently 350 crate/turbo 350, 3:73 gears. Owned since 1984. Painted 3 times (since i have owned it).
Added power steering, auto trans, disc brakes on front and 5 lug wheels. Custom tailgate, c60 grille, rally wheels (8in), custon front seat made out of Youkon 3rd row seat. Ran a 300hp 327 for years. Have been rear ended, rolled, ran thru a fence, miutiple transmissions, 2 or 3 rear differentials, 2 front suspensions etc
blu1964 #1566625 12/28/2024 12:26 AM
Welcome back and looking forward to seeing some picture of your 1964 C10! wink
If you need some help with posting pictures, click this LINK for a short video created by fellow Bolter "klhansen" that is probably the simplest way to explain things. If you get stuck just ask and folks will be glad to offer more help. smile
~ Dan
1951 Chevy 3 window 3100
blu1964 #1568376 01/19/2025 6:38 PM
Check the bolts that secure the torque converter to the flexplate before you start taking stuff apart.
Fairly common problem that can cause a lot of aggravation.
Fred
rfs56trk #1568417 01/20/2025 1:56 AM
Fred
Also check the flexplate over real good. Have seen them have the center cracked where it's not easy to see.
BC
1960 C60 pasture art
