3 members (klhansen, Ole49GMC, HandyAndy), 84 guests, and 2 robots.
Topics128,113
Posts1,056,580
Members48,448
Hello,
I have the headlight switch shaft sticking out off my 1953 truck dashboard, but no knob for it. The triangular 'shaft' looks too long. Just get an aftermarket new switch with know to match?
Your help would be my pleasure,
Joerg
~ NORTH OF 49TH
1948 GMC Model 9434 Frame rebuild
1953 Chevrolet 1314 1/2 ton rebuild
Follow along it the DITY Bay
I believe that's already an aftermarket style switch. I have a similar one with a knob that's held on with a setscrew. The original style has the knob permanently attached to the shaft, with a latch to release the shaft from the switch for installation or removal. I don't know of a source for a knob separately, but any knob you might find at a hardware store would work.
Your picture looks like the switch is in the ON position. Will the shaft push in?
Here's a clip from Jim Carter's web catalog.
I think Classic Parts, Classic Industries and such offer just the knob, being that same switch is used for several years and different models. I do say that the 51-52 knob I got that’s maroon plastic has a cruddy set screw. The thing sets kitty-wampus. Got to work on a shim or something to square it up. And the aftermarket retainer nut that comes with the new switch is junk. I ordered a metal replacement one.
Chip
'Rusto-Mod'
'51 Chevy 3600 5 window | C4 Corvette front/rear suspension & drivetrain | everything else looks old and stock
'92 GMC Sonoma GT #15 of 806
'91 GMC Sonoma GT Extended cab 1 of 1
Trucks, Trucks.....and more Trucks
klhansen, the switch is in the 'off', pushed-in position in the picture.
~ NORTH OF 49TH
I got a switch that looks just like that with my wiring harness from Speedway.
I got a spare knob from Classic Industries and trimmed the headlight switch shaft to the right length for the knob to sit at the dash when turned off.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
