11 members (52Carl, carbking, Gdads51, Bill Hanlon, 1955 1 Series, 2-Ton, Robert Crandall, fonz8261, greenie-reddy, 2 invisible), 116 guests, and 1 robot.
Topics128,124
Posts1,056,347
Members48,441
#1567276 01/03/2025 6:32 PM
Hello
Does anyone have any suggestions on a good stain/sealer that could be used on the wood strips on my 1950 GMC 1/2 ton.The wood is white pine and was bought as a kit. I have used Minwax stain with a urethane sealer which lasted about 3 years. Note: the truck does not sit outside except for short drives and shows.
Thank you
Rmcea #1567280 01/03/2025 8:01 PM
Insomniac
Insomniac
I used Minwax Helmsmen spar urethane on my maple boards and I'm pleased with it; it's held up very well. Like yours, our truck is a garage queen.
I did not stain the wood first. I wonder if the stain you used is compatible with the sealer?
Helmsman
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Rmcea #1567287 01/03/2025 10:19 PM
O Online: Content
I am a strong believer / promoter of Cabot Semi-Solid, oil based stain. I used it on my mom's barn. The previous application lasted 18+ years before fading.
This picture was taken a few days before Christmas. The barn was stained 4 years ago. This is in Georgia so the sun beats on it relentlessly.
The siding is T1-11 plywood, which hasn't rotted or deteriorated in any way over the last 42 years. No sealer needed with oil based stain. Applied to a truck bed that sits in a garage, it should last forever.
1950 Chevrolet 3100 (Ol' Roy)
Rmcea #1567580 01/07/2025 5:38 AM
Since I am going to use my truck as a truck and not a show Truck I am going to go old school and just use Boiled Linseed Oil. I have used Linseed oil for a couple of other projects. My process is this. Coat every side (6) of each board. Once a day for a Week. Once a week for a Month. Once a Month for a Year. Then Once a year from then one. Now I Realize that getting all the Edges after assembly is not going to be possible. I am figuring that I will assemble the bed wood after the "Once a Week for a Month" step. Then I will just coat the Top and Bottom from that point on.
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
Helmsman
Show or not , a good finish is a good finish. Yeah,I`d use a spar finish. I think I did 8 coats.
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
Thanks for your suggestion
