| | | Forums66 Topics128,090 Posts1,056,018 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2024 Posts: 8 'Bolter | | 'Bolter Joined: Dec 2024 Posts: 8 | Is anyone able to tell me if the Ring and Pinion can be changed without any disassembly of the carrier. Differential was rebuilt just a few thousand miles ago. 1955 1st, with original rear end. Presently has a 3:90 want to go to something higher. Thanks.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You have to partially disassemble the carrier to remove the axles when you go to remove it. It is an easy job to remove the gears inside the carrier & replace them when you get ready to put the axles back in. If you can replace a ring & pinion satisfactorily you shouldn't have any trouble putting the gears back in the carrier.
George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2010 Posts: 2,307 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,307 | I don’t think you can get the pinion by the carrier if left in place or for that matter the ring gear . | | | | | Joined: May 2015 Posts: 11,054 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,054 | I don’t think you can get the pinion by the carrier if left in place or for that matter the ring gear . Not unless you're a woman who can remove her bra underneath her blouse.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2024 Posts: 8 'Bolter | | 'Bolter Joined: Dec 2024 Posts: 8 | Thank you Wrenchbender and Kevinski. I am no familiar with differential work and was looking for info that might help me to do this myself. Shop wants 500 in labor. Trying to do as little disassembly as possible. | | | | | Joined: Apr 2004 Posts: 5,074 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,074 | I bet this bunch to walk you thru a bunch of it, if not all.
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"We make a living by what we get; we make a life by what we give." -- Winston Churchill | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Barry with an attention to detail it is easy stuff. Take a look at my Tech Tip on the matter: 3:55 Gear Swap
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Dec 2024 Posts: 8 'Bolter | | 'Bolter Joined: Dec 2024 Posts: 8 | | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Barry, where is VA do you live?
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Dec 2024 Posts: 8 'Bolter | | 'Bolter Joined: Dec 2024 Posts: 8 | Ashland.
The technical site is very good except that I have the open drive shaft. Is the rear end made the same?
| | | | | Joined: May 2015 Posts: 11,054 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,054 | If you have the open driveshaft, you might be able to just swap out the center section without messing with the ring and pinion, assuming you can find a good used pumpkin with the gear ratio that you want.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | Anybody who is willing to do that job for $500.00 is either incompetent, or he's stuck somewhere in the 1970s! A fair labor price would be somewhere in the $750.00 range- - - -if you buy all the parts. Jerry
| | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | For an experienced guy this is not really an 8-hour job but aside from the usual hand tools and a stout rattle-gun, you need a big vise, a shop press, a bunch of pinion-bearing shims, a depth micrometer, a dial indicator, an inch-pound torque wrench, a small brush, some hi-spot blue and the knowledge of what to do with them. It's not really a job for a newbie. I've done a bunch of them and consider myself lucky that only one of them howled. In my paid wrenching days, it was the senior guys with master ratings that did unit repair on the bench. The apprentices laid under the trucks and pulled the gearboxes and third members and got all dirty. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | | | Joined: Oct 2019 Posts: 113 59 Apache 3100 | | 59 Apache 3100 Joined: Oct 2019 Posts: 113 | I had my gears replaced by an axle & gear shop(near me) in 2022 for $450 (just brought them the center section). I called them last month & there price is the same. They're price is of course higher if you bring the vehicle or entire rear end. They did fantastic work & removing the my center section was pretty easy. Good luck..
1959 3100, original 235/3 on the tree w/overdrive. Carter YF 2100S carb, 205/75/15 w/front sway bar
| | | | | Joined: Dec 2024 Posts: 8 'Bolter | | 'Bolter Joined: Dec 2024 Posts: 8 | Thank you 1Ton tommy and Festerhairball. What center sections and what are the ratios that might be available? | | | | | Joined: Oct 2019 Posts: 113 59 Apache 3100 | | 59 Apache 3100 Joined: Oct 2019 Posts: 113 | as far as i know 3.38 is the only other gear set available. This guy below is a fellow stovebolter too. I'd ask him if you have specific questions. https://www.ebay.com/itm/276824024320If you drive in the foothills or mountains, you might want to keep you 3.90 gears in there. I know my well used 235 prefers the original gears & I'm going back to them. Good luck.
| | | | | Joined: Dec 2024 Posts: 8 'Bolter | | 'Bolter Joined: Dec 2024 Posts: 8 | Thank you Festerhairball. Relative to finding a center section, does anyone know what I should look for (model year) in the junk yard and would that ratio necessarily be a 3:38? | | |
