3 members (Leo, Gdads51, 1 invisible), 171 guests, and 3 robots.
Topics128,088
Posts1,055,995
Members48,430
#1567515 01/06/2025 7:16 PM
Is anyone able to tell me if the Ring and Pinion can be changed without any disassembly of the carrier. Differential was rebuilt just a few thousand miles ago.
1955 1st, with original rear end. Presently has a 3:90 want to go to something higher. Thanks.
Riding in the Passing Lane
You have to partially disassemble the carrier to remove the axles when you go to remove it. It is an easy job to remove the gears inside the carrier & replace them when you get ready to put the axles back in. If you can replace a ring & pinion satisfactorily you shouldn't have any trouble putting the gears back in the carrier.
George
1972 Chevy c10 Cheyenne Super
I don’t think you can get the pinion by the carrier if left in place or for that matter the ring gear .
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Not unless you're a woman who can remove her bra underneath her blouse. grin not me
Thank you Wrenchbender and Kevinski. I am no familiar with differential work and was looking for info that might help me to do this myself. Shop wants 500 in labor. Trying to do as little disassembly as possible.
Authorized Pest
Authorized Pest
I bet this bunch to walk you thru a bunch of it, if not all.
~ Peggy M
1949 Chevrolet 3804
ODSS Lawman
ODSS Lawman
Barry with an attention to detail it is easy stuff. Take a look at my Tech Tip on the matter:
3:55 Gear Swap
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
Many thanks!
ODSS Lawman
ODSS Lawman
Barry, where is VA do you live?
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
Ashland.
The technical site is very good except that I have the open drive shaft. Is the rear end made the same?
If you have the open driveshaft, you might be able to just swap out the center section without messing with the ring and pinion, assuming you can find a good used pumpkin with the gear ratio that you want.
Anybody who is willing to do that job for $500.00 is either incompetent, or he's stuck somewhere in the 1970s! A fair labor price would be somewhere in the $750.00 range- - - -if you buy all the parts.
1 Offline
For an experienced guy this is not really an 8-hour job but aside from the usual hand tools and a stout rattle-gun, you need a big vise, a shop press, a bunch of pinion-bearing shims, a depth micrometer, a dial indicator, an inch-pound torque wrench, a small brush, some hi-spot blue and the knowledge of what to do with them. It's not really a job for a newbie. I've done a bunch of them and consider myself lucky that only one of them howled. In my paid wrenching days, it was the senior guys with master ratings that did unit repair on the bench. The apprentices laid under the trucks and pulled the gearboxes and third members and got all dirty.
1951 3800 1-ton
In the DITY Gallery
59 Apache 3100
59 Apache 3100
I had my gears replaced by an axle & gear shop(near me) in 2022 for $450 (just brought them the center section). I called them last month & there price is the same. They're price is of course higher if you bring the vehicle or entire rear end. They did fantastic work & removing the my center section was pretty easy. Good luck..
1959 3100, original 235/3 on the tree w/overdrive. Carter YF 2100S carb, 205/75/15 w/front sway bar
Thank you 1Ton tommy and Festerhairball. What center sections and what are the ratios that might be available?
59 Apache 3100
59 Apache 3100
as far as i know 3.38 is the only other gear set available. This guy below is a fellow stovebolter too. I'd ask him if you have specific questions.
https://www.ebay.com/itm/276824024320
If you drive in the foothills or mountains, you might want to keep you 3.90 gears in there. I know my well used 235 prefers the original gears & I'm going back to them. Good luck.
Thank you Festerhairball. Relative to finding a center section, does anyone know what I should look for (model year) in the junk yard and would that ratio necessarily be a 3:38?
