2 members (Hotrod Lincoln, klhansen), 119 guests, and 2 robots.
Topics128,127
Posts1,056,357
Members48,441
My wipers only go from 3 o'clock to 12 o'clock and then back to 3 o'clock. What's most likely the problem?
1956 3100 three speed 6 cyl. Stock with a few upgrades.
Mickey - Which wiper motor do you have, vacuum or electric (both were available)?
~ Dan
1951 Chevy 3 window 3100
Sorry forgot that. Electric.
You might try reading up in the 1955.2 Series Shop manual starting here on how to set them for initial alignment and then check your sweep pattern. Your 1956 possibly has a later electric motor which is covered in greater detail in the 1956 Truck Shop Manual Supplement. Others will probably chime in soon with their experience and knowledge. wink
~ Dan
OK, pulled the wiper arms off and turned on the motor. The transmission shaft appears to not be turning enough to do a compete swipe on the windshield. Only about a half swipe.
7
7 Offline
I believe there is some adjustment on the linkage under the dash, there could be an adjustable sliding arm with pinch bolts, the longer you make that arm, the more degrees of travel will be relayed to the pivot posts. Remove the wiper blade/arm first, make any adjustments under the dash, run the motor and let it park, install the blade/arms and observe the stroke.
Thanks Buckshot I'll have to get someone under there and have a look.
