5 members (Gdads51, KEVINSKI, klhansen, 50_TON, TooMany2count), 103 guests, and 4 robots.
Topics128,193
Posts1,057,249
Members48,466
It’s been a while since I’ve been on here, but just started on a 57 gmc 100, and am trying to figure out what these were for
1950 Chevy 3800
4-53T Detroit Diesel conversion
More pictures in Photobucket
Is that an air brake canister?
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
O Online: Content
Is there one on each side? Any on the rear?
1950 Chevrolet 3100 (Ol' Roy)
Crusing in the Passing Lane
Some kind of shock absorber.
Ed
O Online: Content
There's a regular tube type shock on it.
Snake oil canister
BC
1960 C60 pasture art
There’s no lines or anything, it just sits above the kingpin, my first thought was liquid tire chain, but I thought that wasn’t until the 60s and only for a couple years
1950 Chevy 3800
Can we get pics from any other angles?
I’ll get some more tomorrow
1950 Chevy 3800
Just on the front axle on each side
1950 Chevy 3800
O Online: Content
I wonder if they're some sort of dampers.
B Online: Content
Those are called "road shock dampers" (if I remember correctly). I think they were standard on GMC Suburbans and available as a bolt-on for other small trucks. Somewhere I have a GMC document on them, but I've been looking for 20+ minutes and no luck so far.
No hydraulics in them, just springs and a weight.
O Online: Content
I just looked them up. A guy on another forum says they work really well on rough roads. Offered on GMC '55.2 - '59.
B Online: Content
Part # is 5328170. Only available on 1/2 ton models.
Snapshot below from this page in the 1955-59 GMC Truck Maintenance Manual provides detailed description of the unit and a nice picture to show more details. smile
~ Dan
1951 Chevy 3 window 3100
It's a Shock Dampener assembly. Only available on GMC's of that era. I believe they have some
information on the GMC site.
Fred
Bill beat me to the response.
B Online: Content
Finally found my info.
Bill, Nice cut-away picture and description more detailed than the Shop Manual! thumbs_up
~ Dan
1 Offline
After '59 apparently there were no more gravel roads and no more wash boards over which GMCs operated. If it was a good idea that worked I wonder why GMC dropped it.
1951 3800 1-ton
In the DITY Gallery
O Online: Content
Roads were improving rapidly. Interstate Hwy system was 3 years into construction. Hydraulic shocks were much improved.
Maybe they felt it was superfluous.
Some models of the first gen Camaros had something similar over the rear wheels.
Geoff
1955 2nd Series 3600 235 cid, 4 sp. - Current
1979 Chevy K10 350 cid 4 sp -Sold
1955 2nd Series Wide Window 283 cid 3 sp - Totaled
