| | | Forums66 Topics128,177 Posts1,057,060 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,146 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,146 | I just got done drilling and tapping the nose of two crankshafts (one 216 and one '58 235) thinking I would use my harmonic balancer puller/installer to put the engine back together and use a bolt to secure the balancer. Then I looked at my balancer, which is the one with the hand crank provision (which I want to keep.) The washer and bolt would have to go on the outside of the hand crank lugs.  So that part isn't going to work. The job went pretty easily with the drilling jig, drill and tap from 12Bolt.com. I used my variable speed 3/8 hand drill motor, stopping to let it cool off when it started getting toasty at the recommended slow RPM. It would be better to use a 1/2" drill motor. I will likely drill and tap another 216 crank which may get used, but the jig will be passed on to other 'bolters that may want to use it. The later 235 balancer that doesn't have the hand crank lugs can be bolted on.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2004 Posts: 29,868 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | On the balancers with the hand crank lugs, I bore the lugs for a thick flat washer and a flat head Allen bolt that allows the lugs to still be used with a hand crank. All you need is a boring tool and a lathe to modify the balancer. Jerry
| | | | | Joined: Jan 2000 Posts: 734 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 734 | Problem with the hand crank balancer is it requires a recessed bottom radiator tank (like original) to actually use. One of the best things I ever did for my truck was replacing the old swiss cheese rad, and although it looks original with the hood open, it doesn't have the recessed bottom. Win some, lose some.
Matthew 6:33 1952 Chevy 1/2-ton 3100 Late '55 235/SM420/torque tube 3.55 Dalton Highway survivor (using original 216) www.truckwithaheart.com | | | | | Joined: May 2015 Posts: 11,146 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,146 | Unfortunately, I don't have a lathe and boring tool. I'd have to talk one of my friends who does have a lathe into using that. I do have the original style radiator, though. I may never have an occasion to use the hand crank, but wanted to maintain the original components (on the outside at least.)
