1 members (baldeagle),
82
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2017 Posts: 73 PA OUTLAW | | PA OUTLAW Joined: Sep 2017 Posts: 73 | Hello and Happy Thanksgiving To All! I found a rebuilt short block. I think it was bought through Sears many years ago. The numbers by the dist are T5148. Can anyone tell me anything about this motor, like year, size? It has some rust but maybe cleaned up. Thank you in advance. Glenn | | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | That number doesn't seem to follow the pattern of a factory ID. It's probably one that was put there by the rebuilder. Look for the casting number that is near the oil pan rail on the passenger's side front, and a date code cast into the block at the back above the starter area. Without a good stamped ID number, an educated guess about the original application will be the best thing available. Block casting codes usually span several years of production. If the cylinder head is off, the simplest way to determine engine size it to measure the bore and stroke. Jerry '
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Can you give us an idea of what you think it is? Is it in the 216/235/261 family or the 230/250/929 family??? Post a picture... Mike B  | | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | PMs exchanged with a casting number- - - -57 passenger car 235- - - - -5/57 date code. Jerry
