2 members (49 panel, Nick in Manitou), 22 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#1564324 11/28/2024 3:05 PM
PA OUTLAW
PA OUTLAW
Hello and Happy Thanksgiving To All! I found a rebuilt short block. I think it was bought through Sears many years ago. The numbers by the dist are T5148. Can anyone tell me anything about this motor, like year, size? It has some rust but maybe cleaned up. Thank you in advance. Glenn
That number doesn't seem to follow the pattern of a factory ID. It's probably one that was put there by the rebuilder. Look for the casting number that is near the oil pan rail on the passenger's side front, and a date code cast into the block at the back above the starter area. Without a good stamped ID number, an educated guess about the original application will be the best thing available. Block casting codes usually span several years of production. If the cylinder head is off, the simplest way to determine engine size it to measure the bore and stroke.
Can you give us an idea of what you think it is? Is it in the 216/235/261 family or the 230/250/929 family???
Post a picture...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
PMs exchanged with a casting number- - - -57 passenger car 235- - - - -5/57 date code.
