0 members (),
80
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2002 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2002 Posts: 272 | Does anyone know where i can get a coil spring compressor that will work for my new TCI Mustang 2 IFS springs? I have ruined 3. They will not squeeze the spring far enough and I am veryy nervous about kiling myself if it breaks by cranking it down too far. I have stipped out 2 and bent the 3rd on beyond use. Needless to say I am frustrated and I am not interested in taking it to the shop that welded the Xmember. (see my IFS cost post in the HiPo shop) Help Thanks, Sean | | | | | Joined: Jan 2002 Posts: 244 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 244 | I bought a spring compressor from Harbor Freight. Doesn't Kragens or AutoZone rent these tools out free? May want to check them out. BTW when using these compressor, it's wise to use a length of chain looped the top and bottom links together so if the compressor fails, the spring won't "boing" out at you. | | | | | Joined: Jun 2002 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2002 Posts: 272 | Actually those were the first 2 I tried. I ruined the Autozone one in 1 try. The harbor freight alomost made it once. | | | | | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | These guys have been pretty reliable and have brand name stuff. Tool Warehouse
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Have you, by chance, lubricated the threads on the spring compressor before you tried to use it? That makes all the differance.
