6 members (Robert Crandall, Hotrod Lincoln, 3800GUY, JW51, Wally / Montana, 1 invisible), 78 guests, and 2 robots.
Topics128,082
Posts1,055,961
Members48,430
#1563957 11/23/2024 8:53 PM
It's always one step forward and two steps back with these wrecks.
Anyway, the charging system doesn't seem to be working. What is the best way to determine whether the generator or voltage regulator is at fault? Or, could the problem lie elsewhere?
6v stock system with no additional electrical options.
1950 Chevrolet 3100 (Ol' Roy)
H Online: Content
Call me- - - -the diagnostic procedures are too complex to address with a keyboard. PM if you don't have my land line number handy.
I talked to HRL and through a series of tests have determined that the generator and ammeter are both functioning. The voltage regulator appears to be the culprit. Tomorrow I'll perform some maintenance on the regulator and an original I have on the shelf.
We'll see what happens.
H Online: Content
Here's an original equipment (maybe NOS) Delco regulator-- - -6V negative ground. Price is right, too!
www.ebay.com/itm/335522351237?
Not quite as pretty, but the right voltage and polarity:
www.ebay.com/itm/186229163508?
Business card trick?
1950 Chevy 3100
H Online: Content
His needs a bit more- - - -maybe 1000 grit wet sandpaper to the points, followed by crocus cloth and a cleanup with alcohol.
Jerry,
Copy that!
Thank you
1950 Chevy 3100
Today I cleaned the "new" voltage regulator's points with 1500 grit sandpaper and alcohol. Unfortunately there was no change.
I pulled out the 75 year old Delco Remy voltage regulator that the generator re-builder said was no good. I cleaned that up the same way and installed it.
Voila! It worked. It was charging too high, though at 8.1v. Jerry gave me the lowdown on how to adjust it and it's now charging at 7.3v.
So far. so good. I'm sure something else will pop up with this wreck.
I purchased the NOS Delco Remy voltage regulator on ebay for $40 with shipping. Seems like a good deal to have a spare on hand.
The new one lasted 3 years to the day I discovered it had conked out. (purchased 11-22-2021)
Otto,
The "new one" lasting 3 years, was it an Original Delco Remy ? Or a no name?
Todd
1950 Chevy 3100
H Online: Content
That one is an offshore-made copy. I'm going to see if I can coax a little more life out of it. Sort of reinforces my idea that there are two types of regulators- - - -OEM Delco-Remy, and "WRONG"!
Originally Posted by Shaffer's1950
Otto,
Todd
Regitar. Delco-Remy copy (not a clone due to certain important differences) Made in USA.
Here's the one that came with the truck.
The difference between the new Regitar units and the Delco Remy unit is that there were no adjusting screws on the Field or Armature points.
I was able to adjust this unit from 8.1volts when installed down to 7.3volts
H Online: Content
The copycats save a few pennies every chance they get. On the ones without adjusting screws, the spring tension is adjusted by bending the stationary spring anchor- - - - - -GENTLY! Back in the dark ages, Delco-Remy was about the only regulator manufacturer that used adjusting screws. Autolite, Blue Streak, and most of the others just used bendable spring anchors. One bit of trivia- - - - -the cutout relay, which controls the voltage when the generator and the battery get connected together after the engine starts, has a LEFT HAND thread on the adjusting screw! That means that to increase any of the settings, the screw is turned clockwise. The spring on the cutout relay holds the contacts open, not closed.
Here's the Regitar version without the adjustment screws.
