1 members (Hanks custodian), 264 guests, and 3 robots.
Topics128,089
Posts1,056,139
Members48,435
#1563900 11/23/2024 2:55 PM
Rebuilt 235. All machine work done at local shop. Intake manifold has been machined. Still have intake leak. Can I stack gaskets or is there a better fix?
Did the manifolds get separated from each other during the rebuild? My GMC's manifolds did and when I put them back on they leaked.
My solution was:
1. loosely bolt the manifolds together.
2. install the manifold assembly to the head leaving the bolts to the head a little loose.
3. tighten up the bolts holding the manifolds together.
4. remove the manifold to head bolts leaving the manifold to manifold bolts tight.
5. have the machine shop true-up the manifolds to head surface.
6. re-install the manifold assembly with gaskets and alignment rings.
No more leaks.
Nope. They were never separated
Use a RemFlex gasket. Have the manifolds machined flat while they are bolted together to eliminate any warp. The gasket between the intake and exhaust at the heat riser needs to be replaced anyway, so they should be separated and checked for warp individually. Were the alignment rings used between the intake and the head? They ARE NOT optional.
Well, you have to take it back off to install a new gasket set so you may as well take it to the machine shop to have it trued up.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
The manifold has already been machined when together and yes I used alignment rings. Should I take the intake and exhaust apart now even since it has already been machined.
Do you have part number for remflex gasket? Most places I look are felpro gaskets
Remflex 2027 Exhaust Gasket
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
Go to the Remflex website.
Found it thanks guys
I wouldn't.
I would install the manifolds without gaskets and find where the gaps are.
You may find that when they shaved your manifolds, they took off enough meat to make your alignment rings too long now. A belt sander works well for grinding the rings shorter.
Justice, What/where was your leak??? Info may help another Bolter should they run into a similar problem. wink
~ Dan
1951 Chevy 3 window 3100
Ditto on shortening the rings- - - -they can hold the intake away from the head and prevent the gasket from being compressed enough to seal. The remflex gasket is about twice as thick as the original, which also assures a good seal.
https://www.amazon.com/Remflex-2027-Exhaust-Gasket-Engine/dp/B000TLPAZ0
I`d hold off on shortening the rings. The remflex is thick and will
hold the manifolds further apart.
~ BD.
1 Offline
You want to make sure that the intake side seals completely. Vacuum leaks can cause burnt valves and, worst yet, burnt pistons. Try finding one only 0.040 over piston for a 235.
1951 3800 1-ton
In the DITY Gallery
I just installed the remflex gasket. Fingers crossed it seems to be working. Dial in some timing and air fuel mixture should be good. Thanks guys.
