1 members (Eileen), 99 guests, and 3 robots.
Topics128,079
Posts1,056,310
Members48,442
Anyone have numbers for upper and lower radiator hoses 327-283 V8 in a stock 1950 chassis ? Stock type aluminum radiator
B Online: Content
Someone will ask the question "To what radiator?"
7
7 Offline
On my stock '57 LCF 283, I had to find a hose with the right shape and then cut it down to fit for the upper, I can't remember what I did for the lower but I think I just took the old one to my favorite old time parts house and matched it.
I had to cut this one to fit lower at the line for my 327`s
Depends on your RAD this hose upper worked for me.
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
I will look to see if I have the numbers that I used for my 383 installation. It will depend on what you have for a thermostat housing, I have an adjustable (rotation) angled up version. I do beleive I needed to cut one if not both to fit.
1949/50 3600 Project
Follow in Project Journals
This can be as cheap or expensive as you want to make it, but a combination of rubber/silicone straight pieces and metal elbow straight pieces could be easier and faster than trying to make a specific molded hose fit. And, in my opinion, 100 times better looking than a universal hose.
