1 members (Cosmo),
84
Mod | | | Forums66 Topics128,054 Posts1,055,779 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2022 Posts: 2,446 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,446 | Anyone know what a Zenith model 28 carb with a tag number 11147 was originally used on?? It was not listed in the GMC Master Parts Books that I have. My books cover all the years that the 28/228 carbs were used except I am missing the ’54 and first series ’55 models. I’ve asked the guys over on OldGMCTrucks
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: Sep 2013 Posts: 1,361 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,361 | I bought a mdl. 28 nos Zenith O-10355 for 1937 ~ 1942 Chevrolet from carbking to run on my 1951 216 powered 3600. It’s been a great carb. Don’t know if this helps but I’d suggest looking up carbking, his profile has a portal ( thecarburetorshop.com) his site with tons of info of the type you’re looking for.
RonR
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: Nov 2002 Posts: 2,765 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,765 | GMC number 2194114.
According to Zenith, first used on the 1950 GMC 228 in the FC-100 model.
Jon Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Jan 2022 Posts: 2,446 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,446 | Thanks Jon.
I used the 2194114 part number to look up the carb in my GMC Master Parts Book and there it was, the first carb in the list. I don’t know how I missed it originally. Probably a short between my keyboard and my chair.
| | | | | Joined: Nov 2002 Posts: 2,765 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,765 | You probably originally looked prior to your second cup of coffee!  Jon Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Jan 2022 Posts: 2,446 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,446 | Jon, as long as you have the Zenith book out, I have in my spare parts a Zenith 28 carb with a stamped number 10163C. Anyone know what the original application was? I've checked the 1939-53 and 1955.2-1960 GMC Master Parts Books with no luck. I don't have '54-55.1 books.
My 228 came to me with a Carter YF. I bought the Zenith to try to keep my truck "original", but the Carter ran better so I put it back on. This particular Zenith also has the adjustable high speed jet.
| | | | | Joined: Nov 2002 Posts: 2,765 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,765 | Bill - 10163 is a universal replacement carburetor; never used as original equipment. I would have to pull a print to determine internal venturi size.
Jon Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Jan 2022 Posts: 2,446 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,446 | Not important Jon. Thanks for looking.
