1 members (Jimmie D), 110 guests, and 7 robots.
Topics128,077
Posts1,056,033
Members48,433
#1563283 11/15/2024 1:13 PM
I have driven my 216 in my 1949 3600 for about 6000 miles. All in all i have no issues with it. With the overdrive transmission I can drive it 70 mph no problem. The other day coming home however I got behind a lady driving 20 mph under the speed limit. I went to pass her and she decides to speed up as I get beside her. I had to get up to about 80 mph to get around her. Now I have gotten the old truck up to 80 several times and it seems fine. I see online where the majority of people swap these engines out for 235 engines. Is there that much difference in power? Does it make that much difference? I took a trip to the coast the other day loaded with some mulch and got about 16 mpg running 70 -75 so that isn't bad. I just wondered if the advantage is worth the cost and labor?
Thomaslb #1563284 11/15/2024 1:19 PM
85hp vs 140. Or so.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
Thomaslb #1563286 11/15/2024 1:27 PM
If your truck is performing as you describe, why would you even consider a swap regardless of cost? That kind of performance from a 75 year old truck is excellent. How much faster would you want to drive it, anyway? It wasn't designed to travel any faster than you're already going in the first place.
My truck, without overdrive, cruises between 55 and 65 with no real effort. I have gotten it up to 70 once but that is the absolute limit, I think. I don't feel the need to drive it any faster than that.
If your engine blows up, then start looking for a 235 unless a running 216 falls in your lap. That's my plan.
1950 Chevrolet 3100 (Ol' Roy)
Thomaslb #1563293 11/15/2024 2:28 PM
I agree with Otto, I loved my 216! Drive it until you have issues and then change it. The 216 will run forever. Save your money!
Chris
Thomaslb #1563296 11/15/2024 3:49 PM
A 216 with the right connecting rod clearance should have no problems at any reasonable highway speed, reliability-wise. Problems arise when the rods get a little loose and start pounding away at the Babbit lining of the connecting rods. It's pretty simple to convert the engine to insert-type rod bearings for a Perkins Diesel engine, or with some creative machining, a 235 crankshaft and rods can be fitted. I see no reason to trash a basically good engine simply because most people have forgotten (or never knew) how to keep them running right. Those spray-oiler 216 and 235 engines by the hundreds of thousands helped us win WW II- - - - -how bad can they really be?
Thomaslb #1563299 11/15/2024 4:14 PM
Thomas,
What truck/year are you running? I hope your brakes are top notch in order to support going such a speed. Also, what overdrive gearbox are you running? Sounds like a real nice running rig.
Craig
Thomaslb #1563403 11/16/2024 10:06 PM
Which overdrive transmission do you have?
Thomaslb #1563488 11/18/2024 12:39 PM
I have a t-5 from s-10 I think it is .74 overdrive with 4.56 rear end. I have 16 inch tires. I have updated rear brakes to a bendix style like was on lincolns. I had to fabricate a backing plate but it uses the same drum. The truck is a 49 3600.
Thomaslb #1563491 11/18/2024 1:00 PM
That T5 will not connect to a torque tube driveshaft. It will require an open driveshaft rear end. Folks here have done that swap and can guide you.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
Jethro, His truck is a 3600 (3/4ton) which has the split driveshaft setup. Front half is torque tube from transmission output to carrier bearing, then transitions to an open drive shaft from carrier bearing back to axle. He can simply replace the existing original drive with an open drive shaft to connect the T5 directly to the rear axle. Of course, properly set up with the correct length shaft and u-joints/ends, etc. smile
Edit: This is a topic for the Driveline forum so further discussion should head that way. Back to the "engine" subject at hand. thumbs_up
~ Dan
1951 Chevy 3 window 3100
Thomaslb #1563519 11/18/2024 8:07 PM
The overdrive transmission was to best modification I have done. I can run 70 mph turning 2500 rpms. Someone has put alum. Pistons in it so the babbit shouldn't beat out too easily I think?
Thomaslb #1563552 11/19/2024 2:46 AM
That T-5 with a .74 overdrive, 4.65 rear gears and original height tires (28" tall) is about as perfect as you could do for a 216.
If you find that 1st gear is almost a granny gear, you can get some 215 85 R16 radials (30.5" tall) and dial 1st gear right into a useful first gear.
