5 members (TooMany2count, UtahYork, Gdads51, Rich'sToys, jasrking), 137 guests, and 1 robot.
Topics128,126
Posts1,056,354
Members48,441
#1562976 11/11/2024 3:59 AM
Does anyone have some pictures of how the headliner goes in. Especially the front half. Trying to figure out how to install it.
1954 Chevy 3100
One problem solved doesn’t seem to shorten the list
Montgomery, AL
In Project Journals
Hey T-Doug . Well, your in for a real treat. I've attached some pics. Best advice I can give you is to install the center bow onto the front section and use punch to "re-peen" the front headliner section to the bow. If you take look at the bow, you will see where is was originally "pinched". You'll need to work the front section forward and behind the windshield seal "lip". It will be obvious once you get started. Also, it really helps to have a second set of hands.
Ron - - Dusty53
1954 Chevy 3604
You should have the door windlace installed so you can slip the headliner behind it. It helps hold it in place while you get it worked forward. Also the windshield trim should just be loosely in place as the headliner gets tucked above it. Ron's suggestion of attaching the center bow to the front section is essential.
I was actually surprised that I didn't have that much trouble with mine. I may be doing it again though as I had a windshield leak that softened the headliner at the front center and caused it to pull away from the windshield trim. frown
Thanks for the pictures and tips. I need to order the door windlace. Every step I find another part I need. If I ever do this again I’ll be an expert.
That door windlace is going to be a bear to install I think. The tracks are rusty and hard to get at. One way or another I’ll get it done.
Doug
1954 Chevy 3100
Montgomery, AL
In Project Journals
Clean those tracks out the best you can and spread them a bit. There are also spots where they've been flattened to hold the windlace in place. Use some rubber lube on the dovetail on the windlace also. My friend and I got a good workout installing my windlace. I actually trimmed the dovetail a bit with a dremel grinding wheel on the second one we did.
Thanks for that insight Kevin. I have some silicone grease I was planning to use.
Doug
1954 Chevy 3100
Montgomery, AL
In Project Journals
I don't think I'd use silicone grease. It'll be there forever and bad for painting contamination. I got some rubber lube from the local tire shop, and my friend suggested (and we used for the second side) glycerine based bubble solution his grandkids use. Both evaporate, leaving basically nothing behind.
Hmm. I’ll see if I can find some.
Doug
1954 Chevy 3100
Montgomery, AL
In Project Journals
Moderated by  ndkid275, Phak1
