0 members (),
149
Mod | | | Forums66 Topics128,113 Posts1,056,619 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 264 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 264 | Had the transmission rebuilt by a pro a couple years ago, replaced everything easily sourced, polished gears etc. Have filled it with Dino 90W gear oil. Have issues if rpm's aren't exactly matched shifting into 3rd. Upshifting or downshifting. Was reading a post about "bench testing sm420" and Jerry mentioned 90W Ford tractor oil. Anything I should look for, and would my dino oil be okay for it? Son's a heavy equipment operator and gets it free from work as it's used in his Cats. | | | | | Joined: Jul 2014 Posts: 1,291 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,291 | Get rid of the 90W "modern" gear oil and go get the " 90 WT mineral gear oil" as orginally recommended in the manual . Tractor supply has it as Traveller Brand Ford Tractor Transmission Fluid Mineral Gear Oil. The word is that the modern oils are too slippery and do not allow the right amount of friction for the synchro's to work correctly. Thats the brand I run in my SM420 in my 1954 3600.
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: May 2015 Posts: 11,110 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,110 | As well as being too slippery, anything higher than GL4 gear oil has components in it that will attack the brass synchronizers and other components in older transmissions.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2004 Posts: 29,836 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,836 | One of the problems with the SM420 and similar transmissions is the sheer mass of some of the gears. The synchronizer has a difficult time getting enough of a grip on the gears to match the speed of the two parts that are trying to mesh due to the inertia of the spinning parts. Super slippery lubricant defeats the purpose of the brass friction rings in the synchronizers. Jerry
| | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | I had used hypoid gear oil in mine for years before I realized it was wrong. It never ground into 3rd but It took too long for the syncro to work and was slow shifting. Being an old 2-stick trucker I would take it out of gear without the clutch, wait for the RPMs to fall then drop it into gear with a dab at the clutch, just like I did on the non-synchro big trucks. This went on for so long that I forgot about it completely until it was time to change the gear oil. Then I read about the evils of modern gear oils and mended my ways. It now has SAE90 mineral oil in it and it shifts much better but I still use the old technique as it saves the synchros and one of the brass ones for the older SM420 is no longer available. I forget which one. GM changed the design in the mid fifties and the parts aren't interchangeable IIRC,
1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | | | Joined: Jan 2016 Posts: 264 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 264 | So, since there's no Tractor Supply north of the border I'll have to source some proper oil then. Suggestions for alternatives appreciated. Would this oil be better for the vacuum 2speed rear too? | | | | | Joined: May 2015 Posts: 11,110 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,110 | Shell Spirax S4 TXM Tractor Transmission & Hydraulic Oil, available at Canadian Tire says it's GL-4 rated, which is OK for your transmission. For your rear axle, you can use any Hypoid gear oil, even GL-5 rated, although the same stuff I found above would be OK.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2019 Posts: 4,493 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,493 | NAPA and O’Reilly’s carry GL-1 rated straight mineral oil which is what you want to use. I think (but may be wrong) any GL1 rated oil in 90 weight will work.
Looks like O’Reilly’s bought out Vast-Auto recently so you may have one around you.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: May 2015 Posts: 11,110 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,110 | Anything GL-1 thru GL-4 is OK for synchronizers. I haven't been able to find GL-1 in stock at either local NAPA or O'reilly's, but they can probably order it.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2019 Posts: 4,493 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,493 | As long as it’s not synthetic because it’s too slick for the synchro’s to operate correctly.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: May 2015 Posts: 11,110 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,110 | I doubt that you'll find synthetic in anything but GL-5. There's just not enough demand for the lower grades of gear oil that the manufacturers just make GL-5.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jul 2000 Posts: 2,198 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,198 | So, since there's no Tractor Supply north of the border I'll have to source some proper oil then. Suggestions for alternatives appreciated. Would this oil be better for the vacuum 2speed rear too? I found this Motul product works OK in my 1967 SM420. Bought it at the local auto parts store. Gear oil
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: May 2015 Posts: 11,110 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,110 | I''d be a bit leery of that stuff Gord. It says it contains Molybdenum bisulphide, a sulfur compound, and is rated API GL-5. It says mineral oil, but additives to get it to GL-5 rating may not be good. They do claim it's safe for yellow metals, but it may take a long time to do damage to brass synchronizers.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jul 2000 Posts: 2,198 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,198 | it may take a long time to do damage to brass synchronizers. I turned 70 this year, so I think it should outlast me!
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: May 2015 Posts: 11,110 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,110 | Gord, I hear you about things outlasting you (and me).
