216. where do the large diameter fat washers go on the front engine mount. I just removed the front mount off an engine which someone gave me and they were located between the engine mount and the crossmember on the outermost bolts. I don't know if that is correct or not.
They do go between the engine mount and crossmember. I believe they're called SAE washers.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
I have used them to shim the engine front for u-joint alignment on open driveline. I have read you're not supposed to do that. I have also used front suspension shims, those horseshoe shaped ones.
1951 3800 1-ton "Earning its keep from the get-go" In the DITY Gallery 1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971.
52 Carl - here's some pics from Denny Grahams album, I can send more if needed. Meant to respond last night but got sidetracked.........
Ron - - Dusty53 1954 Chevy 3604 In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel."
