0 members (), 135 guests, and 2 robots.
Topics128,080
Posts1,055,954
Members48,430
216. where do the large diameter fat washers go on the front engine mount.
I just removed the front mount off an engine which someone gave me and they were located between the engine mount and the crossmember on the outermost bolts. I don't know if that is correct or not.
They do go between the engine mount and crossmember. I believe they're called SAE washers.
1 Offline
I have used them to shim the engine front for u-joint alignment on open driveline. I have read you're not supposed to do that. I have also used front suspension shims, those horseshoe shaped ones.
1951 3800 1-ton
In the DITY Gallery
52 Carl - here's some pics from Denny Grahams album, I can send more if needed. Meant to respond last night but got sidetracked.........
Ron - - Dusty53
1954 Chevy 3604
Thanks fellers. Just what I needed to hear.
