4 members (2-Ton, baldeagle, BC59, 1 invisible),
74
9
Mod | | | Forums66 Topics128,020 Posts1,055,345 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2023 Posts: 45 'Bolter | | 'Bolter Joined: Sep 2023 Posts: 45 | When performing a change from a 6v to 12v system is it necessary to change the ignition switch? I believe the answer is ‘no’ but wanted to solicit feedback from this group. Thanks in advance. | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | When I did my change from 6 to 12v, I kept the original switch.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Jul 2014 Posts: 362 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 362 | No.
Mine's been living in a 12v world for 10+ years. | | | | | Joined: Jan 2022 Posts: 2,436 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,436 |
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | For the same load, 12V is easier on a switch than 6V. At 12V, the amp are halved. What the other guys said. Your switch will be fine.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jul 2021 Posts: 213 'Bolter | | 'Bolter Joined: Jul 2021 Posts: 213 | The only thing to change is the headlight switch. The rheostat for the dash dimmer is different. All other switches are just on/off switches, including hi/low headlight.
Chip
'Rusto-Mod' '51 Chevy 3600 5 window | C4 Corvette front/rear suspension & drivetrain | everything else looks old and stock '92 GMC Sonoma GT #15 of 806 '91 GMC Sonoma GT Extended cab 1 of 1 Trucks, Trucks.....and more Trucks | | |
