5 members (Randy Baumann, TexasJim50, 52Carl, dt235sd, 1955 1 Series), 77 guests, and 5 robots.
Topics128,014
Posts1,055,324
Members48,419
#1562486 11/04/2024 3:01 PM
When performing a change from a 6v to 12v system is it necessary to change the ignition switch? I believe the answer is ‘no’ but wanted to solicit feedback from this group. Thanks in advance.
When I did my change from 6 to 12v, I kept the original switch.
Craig
No.
Mine's been living in a 12v world for 10+ years.
Mine for 13+ years.
For the same load, 12V is easier on a switch than 6V. At 12V, the amp are halved.
What the other guys said. Your switch will be fine.
The only thing to change is the headlight switch. The rheostat for the dash dimmer is different.
All other switches are just on/off switches, including hi/low headlight.
Chip
'Rusto-Mod'
'51 Chevy 3600 5 window | C4 Corvette front/rear suspension & drivetrain | everything else looks old and stock
'92 GMC Sonoma GT #15 of 806
'91 GMC Sonoma GT Extended cab 1 of 1
Trucks, Trucks.....and more Trucks
