3 members (Gdads51, 68ironhead, Peggy M), 94 guests, and 2 robots.
Topics128,118
Posts1,056,302
Members48,439
#1561749 10/27/2024 3:21 AM
I drove my truck 2 weeks ago disconnected the battery after I drove it as I always do
Truck always cranks over without issues.
Today went to move the truck and nothing no power not even a click on the starter no headlights
Put the charger/ battery tender for a few hours came home hooked up battery at 97% charge headlights came on for a second and again not even a click on the starter .
Checked the main fuse and is good if turns out battery is good what else should I look for ?
Thanks 52 Chevy truck 235 engine 12v system fairly new wire harness
This is no longer fun
Find the bad ground.
7
7 Offline
Have the battery load tested, if good then check both battery cables for corrosion under the insulation. As HRL pointed out, check the negative cable at the point where it connects to the frame, engine, firewall.
Update charged the battery overnight hooked it up headlights came on blinker flashed for a second but still nothing
Will be checking grounds
Battery could be dead , even with momentary life.
1950 Chevrolet 3100 (Ol' Roy)
Riding in the Passing Lane
You need more then a battery tender to charge it. That is for maintaining a charge when not in use.
You need to get a good charge & throw a load on it to check it.
George
1972 Chevy c10 Cheyenne Super
Battery gave up the ghost..
Clean ALL connections too.
1950 Chevy 3100
Hopefully issue solved got a new battery luckily for me was still under warranty barely. Put it in and truck started up as usual but will be cleaning up grounds and new cables.
Thanks to all
