7 members (Bill Hanlon, Otto Skorzeny, 52Carl, Hotrod Lincoln, TooMany2count, chemanic, 1 invisible),
92
Mod | | | Forums66 Topics128,135 Posts1,056,418 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 295 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 295 | I drove my truck 2 weeks ago disconnected the battery after I drove it as I always do Truck always cranks over without issues. Today went to move the truck and nothing no power not even a click on the starter no headlights Put the charger/ battery tender for a few hours came home hooked up battery at 97% charge headlights came on for a second and again not even a click on the starter . Checked the main fuse and is good if turns out battery is good what else should I look for ? Thanks 52 Chevy truck 235 engine 12v system fairly new wire harness
This is no longer fun
| | | | | Joined: Feb 2004 Posts: 29,817 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,817 | Find the bad ground. Jerry
| | | | | Joined: Feb 2016 Posts: 1,989 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,989 | Have the battery load tested, if good then check both battery cables for corrosion under the insulation. As HRL pointed out, check the negative cable at the point where it connects to the frame, engine, firewall.
| | | | | Joined: Mar 2010 Posts: 295 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 295 | Update charged the battery overnight hooked it up headlights came on blinker flashed for a second but still nothing Will be checking grounds
| | | | | Joined: Oct 2021 Posts: 6,833 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,833 | Battery could be dead , even with momentary life.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You need more then a battery tender to charge it. That is for maintaining a charge when not in use. You need to get a good charge & throw a load on it to check it.
George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2017 Posts: 664 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 664 | Battery gave up the ghost.. Clean ALL connections too.
1950 Chevy 3100
| | | | | Joined: Mar 2010 Posts: 295 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 295 | Hopefully issue solved got a new battery luckily for me was still under warranty barely. Put it in and truck started up as usual but will be cleaning up grounds and new cables. Thanks to all
