3 members (TUTS 59, Southerntruck, WICruiser), 216 guests, and 3 robots.
Topics128,162
Posts1,056,942
Members48,458
I have a 55 235 with mechanical lifters currently being rebuilt.
Is there any difference between valve springs for a mechanical lifter engine and a hydraulic lifter engine?
1955 2nd Series 1/2-ton
"Bolting in New Zealand"
Follow this story in the DITY
Busta1, First off, Welcome to Stovebolt! shake On your valve spring question, below is a screen grab from a 1962 Chevy Master Parts Book. Shows the 1938-53 All (216/235) and 1954-55 235 (except Powerglide equipped - w/hydraulic lifters) used the same valve springs. The Powerglide equipped 235 engines for 1954-55 used the same spring as later 235's and 261's. Others with more knowledge about if the valve springs can be interchanged should be along soon to provide more detail and response to your question.
~ Dan
1951 Chevy 3 window 3100
Busta1 #1561676 10/26/2024 2:27 AM
Yes. 7th column gives seat pressure and height. Different for each motor. I don’t have my 59 chevy parts book handy right at the moment but I believe there are two different part numbers for the springs for 55.
Mike
Busta1 #1561728 10/26/2024 10:43 PM
Other GM engines that use positive rotators on the exhaust valves use a slightly shorter valve spring on the exhaust- - - - -about 1/8", IIRC, to compensate for the thickness of the rotator. Don't some of the 261's have a similar arrangement?
Gdads51 #1561798 10/27/2024 7:22 PM
Thankyou
I think all 261 used exhaust valve rotators, I have a 261 stashed that has them, as does the '59 261 in my 60 C10, 848 head.
BC
1960 C60 pasture art
