Winter is Coming
A good Tech Tip WINTERIZING YOUR TRUCK including a link back to the Forums for additional tips.
I was given 3 used LED lights for my shop. They are rated 120-277V. I would appreciate some insight on how to wire them. I have a 100 amp 220 panel. See the pics. There are black, white and green wires. I’m assuming black is hot, white is neutral and green is ground. Or is green another hot for 220-277 voltage?
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWB In the Gallery My Flicker Photos!
Green will always be ground. It appears that they can run on any ac voltage from 120 up to 277 since the label shows 120-277. It does not show 120/277 which would indicate one or the other voltage. Ground the green, run them on 120 with black for hot and white for neutral.
