4 members (Bucker, Nick in Manitou, Shaffer's1950, 1 invisible), 220 guests, and 2 robots.
Topics128,189
Posts1,057,337
Members48,469
#1561658 10/25/2024 10:39 PM
Former Workshop Owner
I was given 3 used LED lights for my shop. They are rated 120-277V. I would appreciate some insight on how to wire them. I have a 100 amp 220 panel. See the pics. There are black, white and green wires. I’m assuming black is hot, white is neutral and green is ground. Or is green another hot for 220-277 voltage?
LED1
LED2
LED3
LED4
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
7
7 Offline
Green will always be ground. It appears that they can run on any ac voltage from 120 up to 277 since the label shows 120-277. It does not show 120/277 which would indicate one or the other voltage. Ground the green, run them on 120 with black for hot and white for neutral.
Great, that makes it easy. Thank you.
~ J Lucas
1941 Chevy 1/2-Ton
My Flicker Photos!
Just to be clear those light are for a single phase circuit of either 120 volts OR 277 volts...not for 220 volts or 240 volts.
The black wire can be connected to a 120 or 277 source, the White will be the Neutral and the Green the ground.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Moderated by  J Lucas
