| | | Forums66 Topics128,263 Posts1,058,132 Members48,482 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,254 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,254 | Here are a few you might like to read if working on your Stovebolt doors: Panel Door Handle -- Modify a 1947-1951 front door handle to use as a rear barn door (panel) handle -- Hard to find those barn door handles -- no worries now -- by Alvin "Achipmunk" Parris Hanging a truck door by yourself? -- Make a cradle to ease the pain -- Robert "MPandC" McCartney Door hinge plates -- Can't find them? Make them yourself and save $ -- by Vic "vickraft" Leger Door Hinges -- Rebuilding old door hinges on an Advance Design Chevy pickup truck -- by Brian "MARTINSR" Martin Door Hinges -- Rebuilding door hinges with oversized pins and bushings -- When those old doors start to sag, here's a good detailed fix -- by Mike Bakken Door Latches and Strikers -- How to install them to get your doors to close right -- by Alan Horvath Door latches for 1947-1951 -- Some basic info on how the whole system works, plus tips and drawing! -- by Roy Marks Door Alignment -- For an Advance Design truck -- by Brian Stephens Door Panels -- How to make door panels, good step-by-step with pictures -- by Mark "Yukon Jack" Scott
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | |
